Graphics card installation help - Coolermaster1000
I am having problems inserting the graphics card in this case the slot for the dvi ports wont fit in deep enough for the PCI-E connectors to click in place what can I do ?
Did you post this in multiple forums? B7
Assuming you installed the motherboard in the right holes, the PCI-E slot should line up with the opening for the connectors on the bracket.
