I'm building a PC for a friend of mine and he's going to be using 3D Studio Max along with a bunch of 2D graphics software like Adobe Photoshop. He does this stuff professionally and as a hobby. I'm not sure what video card I should get. I've been looking at video card benchmarks and none of them bother to list 3D Studio Max. So, I'm thinking that it's CPU dependant and the video card is irrelevant. I wanted to get one that doesn't use any of the system memory because he's going to need that for the large graphics files he has. It looks like all the X300 and NVIDIA Turbocache models use system memory. So, those are out. It has to be PCI Express. The two I found on Newegg are
The X550. I can't tell if it uses system memory or not. I'm guessing no. It goes for $65.
SAPPHIRE 100118 Radeon X550 128MB PCI Express x16 Video Card - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16814102562
and
Albatron PC5300 Geforce PCX5300 128MB DDR PCI Express x16 Video Card - Retail $59
http://www.newegg.com/Product/Product.asp?Item=N82E16814170067
Both of these support OpenGL 1.5. I'm not sure if any of these graphics programs would need OpenGL 2.0. But I'm guessing no. Any thoughts or suggestions?
So far the system specs are as follows:
Intel Pentium D 820.
4x Maxtor 250GB with 16MB cache
2GB DDR2 667
ASUS P5LD2 Socket T (LGA 775) Intel 945P ATX Intel Motherboard - Retail
450 Watt Fortron PSU
and
2GB DDR2 667
