Bleedblue12345
- Nov 1, 2004
I have 225-250 and need a new SINGLE SLOT graphics card, i was thinknig of a 7900gt or x1950pro, what do you guys think?
This card is a dual-slot card.shoman24v said:I'd get the X1900XT 256MB. About 280 shipped.
peteyboy23 said:I'm going through the same decision now. I read a review at Tech Report, and the 7950 GT spanked the 1950 Pro in every benchmark. A lot of them weren't even close. Nothing I've read so far gives me any reason to get the 1950 Pro, other than cost. Sure, if it's $100 cheaper I'd get it, but I don't believe there's that much of a difference, and I do want to think about how $80 more right now will effect me in 2 years (the next time I'll upgrade).
coolxboxgamer said:for 1 i dont think dx 10 cards will be single slot ( i hope they are but i doubt it), and 2, i might just save up anf buy a new case/sli or crossfire mobo
Endurancevm said:This is how i know: Mine failed, and so has several other users..
Except one of his criteria is "single slot". Every indication I've seen is that the DX10 cards coming out in 2 weeks (GeForce 8800GTX and 8800GTS) are *very much* dual-slot. Power consuming, hot running, monsters. Powerful - VERY powerful - but demanding.inscape01 said:How soon do you need the card? If you can, wait until the Direct X 10 cards come out next month. If anything they'll bring down the prices on DX9 cards if you still prefer one.
That would kind of negate the idea of having a single-slot card...buickgs said:Then buy a vf900...
Bo_Fox said:Just wait a few days until the 8800GTX is released, and then all the prices will be pushed down.
GreyMatterTripp said:If you can wait a year and all the new shit will be even cheaper than before.![]()
Astrogiblet said:Yea, thats a really good idea. Bo_Fox is full of good ideas. The prices should drop pretty significantly over the next few months because of the new cards.. So if you can, wait!You might even be able to get something really high end for your price range.. like.. 7900GTX or something.
tisb0b said:when is that not the case? and by that time there will be newer and better shit anyways buy what you need when you need it no sense in waiting for the next better thing just around the corner because it will never come.
Bo_Fox said:Well, somebody has to mention that $225-$250 is a very tricky price point.
If it were $300, it would be very easy to decide, with only 2 choices.
At $225-250, the best choice would be:
1) 7900GTO, if you can find one!
2) 7900GT 512MB version, if you can find one!
3) 7950GT, if you can find one that cheap.
4) X1900XT 256MB version if 512MB isn't that important for ya...
5) A very good 7900GT 256MB version.
i_am_mustang_man said:good list, but i think your #4 is my #2. althought keep in mind the x1900 is hot and loud (althought the gt's are loud too, no?)
Advil said:7950GT 512MB is going to be $275 cheapest, so over his budget. The 7900GT 512MB should be available in his price range, assuming they are still out there. Yes, they are louder fan speed controll isn't as good. But they are still a heck of a lot cooler than the X1900.
dderidex said:[*]MSI X1800GTO (weakest performance of the bunch, but still a solid offering. 1024x768 with HDR and FSAA in 'Oblivion' is still a possibility. Not an awful fan, power draw isn't hideous.)[/list]
So, with just that set over the past few weeks (2 ATI cards, 2 nVidia cards), I would draw the following conclusions:
* Performance per watt (power demand), nVidia cards DOMINATE ATI cards.
dderidex said:[*]eVGA 7600GT (awesome priceerformance ratio - only $89 AR at Fry's right now for 2/3 of the 7900GT's performance. Still, no fan control = NOISY.)
