Graphic Problem In Games
MAULxx
Im having an issue while playing games where theres some flicker on the screen.
The screen itself isn't flickering, it looks like something behind the game picture flicking in & does it in short periodic moments. I get it in every game I play to differing degrees.
This has lead to a frozen green screen in GRAW2 & dirt 2.
Both Dragon Age Origins & Mass Effect 2 do it but it's less intrusive but noticable. Haven't crashed yet though.
as far as I've noticed this problem is only when playing a game.
I'm currently running an old ver of Catalyst Control Center & old driver because it has the scaling options to fill out my entire screen.
The GPU is a XFX 5850.
Anything else I can try? Should I try reseating the the card on the Mobo?
Thanks for the help & suggestions.
Processor: AMD Phenom(tm) II X4 955 Processor, MMX, 3DNow (4 CPUs), ~3.2GHz
Memory: 3326MB RAM
Hard Drive: 1 TB
Video Card: XFX ATI Radeon HD 5850
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.090804-1435)
Motherboard: GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX
Computer Case: AZZA Solano 1000 Black
have you tested it with any of the new drivers though and even without filling the screen does it present the same problem?
i have had many problems with the same card but seems to be getting better with every update of the catalyst control center and driver update.
I just installed CCC 10.1
Driver Packaging Version 8.69-091211a-094914C-ATI
Catalyst™ Version 10.1
Provider ATI Technologies Inc.
2D Driver Version 6.14.10.7039
2D Driver File Path System/CurrentControlSet/Control/Video/{50D99109-A94A-4098-92F8-EFB0C75C1454}/0000
Direct3D Version 6.14.10.0723
OpenGL Version 6.14.10.9252
Catalyst™ Control Center Version 2009.1211.1547.28237
AIW/VIVO WDM Driver Version 6.14.10.6238
AIW/VIVO WDM SP Driver Version 6.14.10.6238
I fired up Dirt 2 & didn't see any problems at all. I' test my other games but I'm thinking they will be ok as well.
Now, if I just knew how to make it fill my screen.
Too bad there's no overscan adjustment for this.
There's really no use to test the other games as I won't be using this ver because of the overscan problem.
I just downloaded CCC 9.9 & I'm gonna try it.
What type of display & res are you running that is having this problem? My setup has basically autodetected whatever monitor I've plugged into it without any problem.
I running a Panasonic Viera plasma @ 1920x1080.
Tried to install 9.9 but that aint happening on my system.
Installed & running 9.10 now...
Driver Packaging Version 8.661-090923a1-083739C-ATI
Catalyst™ Version 09.10
I tried Dirt 2 & Mass Effect 2 & had no issues but I think 10.1 is a better driver. Things seem to flow smoother. Screen transitions (like when you start up win or shut down a game) has a wierd discoloring look with 9.10. At least it has the overscan.
I'll be testing it more tonight & tomorrow but what little I've played my original issue isn't present.
Is there a way to run a newer driver & an older CCC ver?
