Graphic card Thermal pads for memory
Dave65
Anyone know what size the thermal pads for the memory on AMD reference card are thickness wise?
Specific to the 5700XT?
Kids got a hold of the blower with the pads still on it while i was putting on the Morpheus II cooler, needless to say they are ground pulp now.
I believe they are .5mm. the pads that came with my EK block are .5mm for ram and 1mm for the Vregs.
Hope that helps. If notbody gets back to you I will measure the stock pads with a caliper if I can get to it this weekend.
Thank you, sir, I ordered the .5mm if they don't fit always good to have around.
