Grandpa_01
[H]ard|DCer of the Year 2013
- Jun 4, 2011
When I got home frome some of my equipment was on the front porch.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370576387595&ssPageName=ADME:L:OU:US:1123 http://www.ebay.com/itm/140684804589?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 any way no memory yet but I have some mix and match DDR3 Laying around and figured I would give it a try so I installed 1 CPU and 2 sticks of OCZ DDR3 1600 7-7-7-21-1T @ 1.65v the board set it to 1066Mhz 7-7-7-19 @ 1.54v which was surprising to me because I thought 1.5v was its maximum. I then installed an OS Vista Ultimate 64bit because it was handy did some testing and all was well.
I then decided to install a second CPU and used some SuperTallent DDR3 1600 7-7-7-21 @1.65v the board set this to 1333Mhz 7-7-7-21 @ 1.54v and it left the OCZ at what it originally set it at. I was a little surprised that it was able to boot and run with no problems running 2 different memory speeds on the 2 CPU's.
Any way I will play with it some more tonight and see if I can mess it up I have a coupple of days before the memory gets here.
A quick question will Ubuntu 10.10 work and recognize all 4 CPU's or will I need to install a different OS.
