Hi all,
Just a simple question. I am building a presentation computer and I need at least 4 display outs. What would you suggest by best solution be?
I'd prefer the use of DVI as opposed to HDMI, and so I guess I am limited to two outs per card. Should I just buy 2 GT630's (or something similar)?
Also, is there interoperability between discrete and onboard graphics at the moment? I'll be using an Intel chip. Can I use onboard and the discrete at the same time? Is this dependent on the versions I use?
Thanks for your suggestions
