GPUGrid
Discussion in 'Distributed Computing' started by Gilthanis, Aug 8, 2014.
  1. Gilthanis
    Gilthanis [H]ard|DCer of the Year - 2014
    7,409
    Jan 29, 2006
    It appears that they will be adding Virtualbox apps
    http://www.gpugrid.net/forum_thread.php?id=3838#37524
    I am adding this app_config info in the first post so that any whom come here will have easy access. This allows for 2 tasks to run on your GPU at a time. You can change the numbers to run more, but it is up to you to decide what maximizes your points on your hardware.:
    <app_config>
    <app>
    <name>acemdshort</name>
    <gpu_versions>
    <gpu_usage>0.5</gpu_usage>
    <cpu_usage>0.3</cpu_usage>
    </gpu_versions>
    </app>
    </app_config>
    Many people don't see an increase in efficiency by running more than one work unit, however it is up to you to test and decide based on your specific hardware.
    Edit: I created an account called HardOCPtest so that anyone whom wanted to test or contribute anonymously could do so.
    to attach a computer to your account without using the BOINC Manager.
    To do so, install BOINC, create a file named account_www.gpugrid.net.xml in the BOINC data directory, and set its contents to:
    <account>
    <master_url>http://www.gpugrid.net/</master_url>
    <authenticator>111740_8a218e5a7cf06d5f3ffb3fb12418e67c</authenticator>
    </account>
    [​IMG]
  2. Nicolas_orleans
    Nicolas_orleans [H]ard DCOTM May 2016
    352
    Oct 7, 2012
  3. EXT64
    EXT64 [H]ard DCOTM x2
    376
    Mar 27, 2013
    Yep - annoying. I went back to testing ocores for a little while (come back proteneer!).
  4. EXT64
    376
    Mar 27, 2013
    I was able to get mine to upload (and to get new work) a few minutes ago.
  5. Nicolas_orleans
    352
    Oct 7, 2012
    That was also my plan, but due to maxwell I had to install cuda 6 sdk... Which version of GCC did you use when executing the .run from nvidia's site (the one for 13.04) ? 4.7.3 or 4.8.2 (default for 14.04) with -override compiler flag ? (I posted more info on irc)
  6. ChristianVirtual
    ChristianVirtual [H]ard DCOTM Mar 2016,Aug 2017
    2,321
    Feb 23, 2013
    Got my first badge: Gly
    (I know, I know, that was easy) :rolleyes:
    But seems smooth overall on GTX 780.
  7. Gilthanis
    7,409
    Jan 29, 2006
  8. Gilthanis
    7,409
    Jan 29, 2006
  9. Gilthanis
    7,409
    Jan 29, 2006
  10. RFGuy_KCCO
    RFGuy_KCCO [H]ard DCOTM x2
    591
    Sep 23, 2006
    I was surprised to find I am placed #1 for the fastest NOELIA_SH2 WU time. Pretty cool. :cool:
  11. Gilthanis
    7,409
    Jan 29, 2006
    I saw that. Congrats by the way!
  12. Nicolas_orleans
    352
    Oct 7, 2012
    780Ti I imagine, what's your OC ? :)
    Congrats !
  13. tjmagneto
    tjmagneto [H]ard DCOTM x2
    3,032
    Aug 6, 2008
    Wow! The numbers for my 780ti haven't' been all that great as it is throttling itself due to heat. I need to fix that problem. :(
  14. EXT64
    376
    Mar 27, 2013
  15. Patriot
    Patriot [H]ard|DCer of the Month - March 2011/June 2013/De
    2,519
    Dec 15, 2010
    My dual gpu cards outperform by doing 2 at once... but I will never make it on those charts.
  16. tjmagneto
    3,032
    Aug 6, 2008
    Moar Cowbell!
  17. RFGuy_KCCO
    591
    Sep 23, 2006
    Thanks! I am actually running it at the stock speeds (well, stock overclocked speeds). 1097 GPU and 1750 memory.
  18. Nicolas_orleans
    352
    Oct 7, 2012
    To my great surprise, my fastest GTX 770 has been awarded #15 for GIANNI_trypbenContacts1MC2, #9 for NOELIA_TRP188 :)
  19. Nicolas_orleans
    352
    Oct 7, 2012
    Back to comparison chart (yes it took me some time to collect data), here are my numbers :
    - GTX 770 - average 425 000 PPD - maximum 475 000 PPD - average is better than chart
    - GTX 750 Ti - average 250 000 PPD - maximum 275 000 PPD - average is lower than chart*
    - GT 640 - average 60 000 PPD - maximum 73 000 PPD
    this is mostly for august work units running 24/7, september is slightly higher with the new batches.
    *I used the original GPUGRID forum to decide if I shall by a 750 Ti, and found the value reported in forum post was "the best case" and not representative of average long term performance. Slight disappointment :)
  20. EXT64
    376
    Mar 27, 2013
    However, 750Tis are so light on power, I still love them. You can shove them into just about any computer (any PSU) and they will run cool and quiet with good points.
    Edit: is your 750Ti OC'ed (or factory OC'ed)?
  21. Nicolas_orleans
    352
    Oct 7, 2012
    Yes, factory OC'ed @ 1306 MHz.
    And I like this card for sure. Just wanted to state a more realistic performance level than the gpugrid forum chart, so potential buyers are correctly advised :)
    Changing topic but... anybody ordered a 980/970 ? :)
  22. Nicolas_orleans
    352
    Oct 7, 2012
    Changes have happened to the scheduling policy to better adapt CUDA version to driver capability.
    Please note that if you have a driver >= 343.00 on Linux, you will only get acemd short version 8.46 since CUDA 6.5 version of acemd long has not yet been released for Linux. That will decrease your PPD, though there is some excitment to be cutting edge :)
    Original post : http://www.gpugrid.net/forum_thread.php?id=3874
    Current CUDA 6.5 app is more or less a recompile, optimized version with performance improvement over CUDA 6.0 app should be released this winter.
  23. Nicolas_orleans
    352
    Oct 7, 2012
    Acemdlong CUDA 6.5 app is live now, you can safely update linux rigs to driver 343.22
  24. Jathanis
    Jathanis [H]ard|DCer of the Month - Feb. 2013
    983
    Apr 22, 2008
    I know this a bit late on the chart, but I've been averaging 430K-435K on a stock 680 - far above the 380K shown... :)
  25. tjmagneto
    3,032
    Aug 6, 2008
    #2 with the NOELIA_SH2 scores @ 2.65 hours :)
    This is even with a bunch of rigs with GTX 980s in my rear view mirror. :D
  26. Gilthanis
    7,409
    Jan 29, 2006
    Has anyone else noticed heavy IO's while running a CPU MT work unit? My 2P 2ith 32 threads is seeing a ton. Even if I suspend work units I am still seeing high usage. This could be caused by the work unit not adhering to the BOINC settings which does pop up from time to time with some projects. Being that these are still test work units, it could be very likely. I just want to make sure whether I am the only one seeing it.
    I can't tell if it is these work units or possibly RNA work that was suspended. However, one of them was still using threads and heavy IO's.
  27. Gilthanis
    7,409
    Jan 29, 2006
    Well... it turned out to be the RNA work units causing all of my chaos. I aborted both of them and everything is running smooth again. First time that has happened.
  28. Gilthanis
    7,409
    Jan 29, 2006
    I got this in my Notices in the BOINC Manager on the 19th.
  29. WesM63
    WesM63 2[H]4U
    3,284
    Aug 29, 2004
    Not too many people must be participating. I'm placed in the top 30 in every WU i've completed. Best was #7 in GERARD_CXCL12_adap_LIG1.
    Single Asus STRIX GTX 980 @ stock clocks. Might turn it up a bit and see how it does.
  30. Gilthanis
    7,409
    Jan 29, 2006
    I think what it is.... is that there aren't a lot of people with 980's.... lol There were a lot that jumped on the 780 band wagon when it was released.
    Anyways, congrats. That isn't an easy task.
  31. WesM63
    WesM63 2[H]4U
    3,284
    Aug 29, 2004
    I suppose that makes sense.
    [​IMG]
    I bumped it up about 20Mhz on both GPU/Mem but i don't think i'll catch multiple card systems.
  32. Gilthanis
    7,409
    Jan 29, 2006
    http://www.gpugrid.net/forum_thread.php?id=3988#39575
  33. RFGuy_KCCO
    591
    Sep 23, 2006
  34. Nicolas_orleans
    352
    Oct 7, 2012
    There is an issue with these WUs that will yield an error when sending results, and a complete loss of credit. Workaround is some manual modification for each WU of the first 400 WUs batch. New WUs shall have been fixed. More details in the original link provided by Gilthanis.
  35. RFGuy_KCCO
    591
    Sep 23, 2006
    Thanks for the heads up! I was able to modify my client_state.xml file before my WU was finished, so this one should pass and grant me credit.
  36. RFGuy_KCCO
    591
    Sep 23, 2006
    That very long WU finished and validated, so the manual fix worked. It took just under 29 hours to complete.
  37. Gilthanis
    7,409
    Jan 29, 2006
    Keep your eyes open as there may be some changes soon...
    http://www.gpugrid.net/forum_thread.php?id=3995
  38. WesM63
    WesM63 2[H]4U
    3,284
    Aug 29, 2004
    Tempting, I have 280X here I could give it a go on but those stupid things are hot and consume twice as much power.
  39. RFGuy_KCCO
    591
    Sep 23, 2006
  40. RFGuy_KCCO
    591
    Sep 23, 2006
    Not so sweet... All the WU's failed immediately after they started. This is obviously an Alpha test.
