GPUcore on a 260
lehmann
Is there any way to keep the priority set to medium permanetly. In the past 4 days my card has only been putting out 4000k ppd. if i set the priority to medium or higher i get 9200 ppd @675/1560 with temps in the mid 50's. can the config folder be manually set to say high?
You can try using SetPriority - configure it to to start when Windows starts. You'll want to set the presets for both FahCore_11 and FahCore_14 -- these are the two cores the GPU client currently uses depending upon the WU.
