This problem just popped up a couple of days ago. The only thing that changed was I installed The Evil Within 2 and Middle Earth: Shadow of Mordor. Those are the only two programs I installed since I started getting this error. "Application has been blocked from accessing graphics hardware. GPUBoost_nvidi has been blocked from accessing Graphics hardware.
Actually, before I started getting the error, I remember videos, movies or YT videos started stuttering while running. It was as if the video I was watching was corrupt, but it did this with everything! Before I received the error I looked at what was running in Task Manager and saw GPUBoost. I don't know how long it's been there, but I haven't noticed it before, but maybe it's not new. Anyway (at first) I noticed playing games wasn't a problem, but videos are choppy. I disabled GPUBoost_nvidia.exe and everything is fine. I went to the folder and it has GPUBoost, GPUBoost_nvidia.exe, GPUBoost_amd.exe and TOR.exe among others, but those are the main executable files that I don't recall seeing before. I was using GeForce 385.69 drivers when I started getting that problem, so I properly upgraded to 387.92 and nothing changed. Actually, it got worse. That's when games start crashing. If I don't end the GPUBoss_nvidia.exe process before I play a game (any game) I start getting that error about 15 to 20 times and then the computer Freezes and I have to do a hard reset. Ctrl+Alt+Del doesn't respond at all.
I'd rather not have to end the process because doesn't Nvidia's GPUBoost 3.0 protect the card with overvolt protection as well as throttling down if the GPU gets too hot. I thought I read it also is responsible for keeping the fans from spinning up until it hits a certain temp, which I can't recall at the moment. Anyway, I know it's this process, but I don't understand why it not only didn't get better but got worse when I installed the newest driver. Can I delete the folder? I'd rather not, but if I must it's located in user/AppData/Roaming/GPUBoost
Thanks in advance!
Here's a screenshot of the error.
Thanks in advance!
![GPUBoss Nvida Error.png GPUBoss Nvida Error.png](https://cdn.hardforum.com/data/attachment-files/2017/10/92811_GPUBoss_Nvida_Error.png)
