GPU-Z is 0.5.9
Catalyst version 11.12
Picked up an Asus 7970 (reference card) the other night and wanted to do a mild overclock while I wait for my waterblock. Essentially, when I up the clock speeds using CCC, GPU-Z will report the change on the 'graphics card' tab, but on the 'sensors' tab, the core and memory speeds never pass default settings. Not sure if GPU-Z simply isn't recognizing the change accurately, or if the overclocked settings aren't sticking for some reason. The above readings were taken using furmark as well as a 10 minute session of Skyrim...clocks stuck at 925/1375 in GPU-Z.
Voltages are stock aside from setting power control settings to +20%
