GPU-Z 0.2.5 temp readings
vexvegaz
does anyone know what each diode sensor readings represent?
i have 3 gpu temp reading in gpu-z. temp 1(28c), temp 2(36c), and temp 3(32c).
im pretty sure the hd 4850 is not a dual/triple core gpu.
VRM and Ram for cards that support it.
Here's the support forum for the program. You should be able to find all you need to know there as to which is which.
