vortec4800
- Sep 19, 2003
I'm trying to decide if I should buy a GPU waterblock for my Radeon 9800 (which is at a high overclock) to put in my soon-to-be watercooled system. If you attach the GPU block in line after the CPU block, which seems to be the way its normally done, wouldn't that actually heat up the GPU considering all the hot water from the CPU block exhaust is going into the "cold" water intake for the GPU block? This seems like it would not be effective at all, though I don't really see a better way of doing it. Is it worth having an extra waterblock, or should I just stick with good aircooling for the video card?
