GPU usage problem, not 100% across 3 cards
Camaroz06
Hey Guys,
Been running my GPU3 clients on my new GTX460 with my GTX480s the past day and just noticed that GPU#3 (as labeled in afterburner) isnt running at 100% usage, it goes from 100% to 30% and waivers.
How can I get all three cards running 100%? CPU is the i7 rig in the sig.
Thanks,
Eddie
you dont have them running in SLI or anything correct? you also have them running on 3 different clients? also what drivers are you using? also check to make sure the cpu usage on the client is set to 100%..
