until you figure out what your other specs are then you do not need to buy a video card. most people around here never even bother to ask anymore.will soon do so.m a total newbie here.dont knw how to mention about d specs of my system as written below d posts of other members.need to get acquainted wid d forum.m playng at 1080p.
ty. you left out power supply though which is still very important to know. a gtx560ti 448sp would be the very lowest card to upgrade to since your gtx460 is already pretty decent. I would probably wait a few weeks though since AMD will be releasing new cards in early to mid January. also I would go ahead and upgrade your ram since it is so cheap right now.INTEL CORE i5-2500 CPU, ASUS P8P67, 2x2Gb DDR3-1333, WD 500GB, MSI GTX 460 1 GB,, WINDOWS 7 x64 ULTIMATE
Personally I had a similar setup and got a 6950 2GB for <$250. It performed a lot better, especially when unlocked to the 6970 BIOS.
and where can one get this 570ti you speak of?i personally like 570ti
no you cannot sli two completely different cards.he got it from china,i guess.
rather than upgrade cn i get a 550ti?does sli wid diff models work.i heard it does from anothr forum.
You can CFX certain different models of AMD cards, but you cannot SLI different models of Nvidia cards. You can SLI cards of the same model with different settings, but that can also cause problems occassionally, at best the SLI will only work at the speed of the lowest setting card. (IE a if you can get them working in SLI, a GTX 560 Ti 384 and a GTX 560Ti 448 will work at the speed of the 384).
You sure about this? The 560ti use GF114 like the 560 while the 448 uses GF110 like the 570 and 580.
Unless I'm mistaken, you could SLI the 448 with the 570 but not the 560ti.
