GPU Sleeping?
carlbme
I added another card to my system and now the other card is sleeping.
I was running cpu (fx8530)/gpu0 (radeon 7770)/gpu1 (gt640)
I added another card to my system - gtx650 (read by f@h as gt650) and it has taken over the WU my 640 was working on. The 640 is now stuck running at 0% after several hours, and MSI Afterburner is showing the gpu at 0% usage.
Is there anyway to force it to start?
Secondly the gtx650 is running at 99% as was the gt640 before it. However the radeon7770 only runs around 43%. Is that normal? Is there a way to force the radeon to 99%?
I have discovered the issue. It seems it is related to the changes I made earlier. It appears it does not like the fahcore_17. When I add the "client-type:advanced" and have it update to the fahcore_17 the three cards just sit idle.
Not sure if this is an issue with the hybridized ati+nvidia setup or not. Returning them to fahcore_15 and fahcore_16 (at least until it's retired) brings the cards back to life.
