GPU servers down
Mine was just puking EUE's yesterday, didn't notice because I was at work... alan pointed it out last night, so I just killed it for now...
Don't really know what the hell happened, it was 100% stable for quite a while and then BAM!!! Nothing but EUE after EUE.....
Did you update the core from v1.09 to v1.13 or v1.15 ??
The new core puts more stress on the GPU, hence more PpD.
If you were just stable on the old core, you could have become unstall with the new one.
I had a couple of GPU that did not grab work first time.
But they've all got work now.
Luck ........... :D
No updates, didn't change a thing...
I uninstalled the client and reinstalled... we'll see what happens.
Well that was fast....
Code:
[20:56:59] Project: 4744 (Run 4, Clone 393, Gen 7)
[20:56:59]
[20:56:59] Assembly optimizations on if available.
[20:56:59] Entering M.D.
[20:57:05] Working on p4744_lam5w_300K
[20:57:05] Client config found, loading data.
[20:57:06] Starting GUI Server
[20:57:13] mdrun_gpu returned -1
[20:57:13] Going to send back what have done.
[20:57:14] logfile size: 0 info=0 bed=0 hdr=25
[20:57:14] - Writing 558 bytes of core data to disk...
[20:57:14] Done: 46 -> 85 (compressed to 184.7 percent)
[20:57:14]   ... Done.
[20:57:14]
[20:57:14] Folding@home Core Shutdown: EARLY_UNIT_END
I'm having the same issues on my second ati based system. 3/4 HD4850s do not have any work. Based on the log file i think it is version 1.10. Should it be that ?
Code:
[20:56:59]
[20:57:14]
It might be time to flush and reinstall the driver.
I'm not having any problems. All are going fine. I already updated to 1.15 core.
I'm getting hours of waiting for work packets inbetween a few working fine.
Sorry everything seems to be working ok now and it was just for about 20 minutes this morning, i think it is just my sick addiction of always checking what my clients are doing and making sure they are folding away:D
Glad to hear you got your issues worked out. Just outta curiousity, did you update or did it just start working again? Im having an issue were Im folding as hard as before, but the results don"t seem to be being sent at the end. It will however move on to the next and keep folding...did this all night, probably 3-4 WU, but in the morning it showed 0 points for the past 4 updates, and yet when i check the systray, yup, she still crunchin something away. This happened once before where it appeared to be folding for about 12 hrs but showed no points/wu, and then on the 4 update it gave me 4x my normal points. Its like it stored them up for some reason and then send all the results at once. :/ I have never had that happen to me before and i have watched religously since I began 3 months ago. Is this normal? Im nervous to update if it will mean losing 10-15 WU...
Ok, update, while I was posting i decided to check Stanfords site and it shows the missing WU's and even reflects an increase in my world rank, so I am assuming that the results are getting to thier intended destination, just not being reflected on our site. On the same hand our site doesnt show ANYONE getting any...wassup with that???
FLECOM...??? Somethings just not right...
the hardfolding stats havent been updating for me either
can be two things, stanford's stats server isn't exporting the stats for 3rd party sites properly or the new hardfolding stats site has a little glitch. I'm banking on the latter due to the fact other 3rd party sites are updating properly. i'm sure someone will work it out.
everything is good on my end with the newest ATI core 1.17, those getting EUEs may want to bump any core clocks down if running over spec (i'm running all stock core clocks with no EUEs). Only minor thing i'm seeing is some busy GPU work servers denying connections at times. :cool:
everything is fine on our EOC Stats so I'm thinking its our stats site
the .74 server isn't letting me connect to get work. Argh, if it isn't one thing it's another with Stanford!!!
My production looked alot like that shot of FLECOM. I thought maybe my internet connection was down (I'm offshore, so no way to check it), because I wasn't producing anything at all. No PS3 or classic clients either. Looks like it's getting back to normal.
Guys, seems like it is happening again. a couple of clients keep trying to get work but there isn't anything downloading.
