I'm using an MSI 560 Ti on a ASRock ITX MB.
Things have been fine until recently when I took the system apart for cleaning and removed most of the components.
Upon putting the system back together, I got a bunch of aberrations such as uniform vertical lines/squares, etc across the screen. Thinking that perhaps the GPU wasn't properly seated, I removed the two screws that bolt it to the back of the case and reseated it. A brief test and everything was perfect, but after putting the 2 screws in again, I'm getting the same problem.
The 2 case holes don't seem to line up perfectly with the GPU holes, but they're only maybe 1mm off. I guess the stress of putting the 2 screws in is enough to knock things out of wack, and this just doesn't seem right considering the mounting holes are only slightly off. Are GPU/MB contact areas typically so hypersensitive?
Any ideas what could be going on here?
Thanks
Thanks
