[H]ard|DCer of the Month - February 2007/January 2
I could not get Vista Home Premium working with 3 or more 9800GX2 cards.
It counts all 3 outputs per card as valid and max's out out at 8 outputs.
So I could only load the drivers for 5 GPU cores.
XP only counts 2 outputs per card and so will run 4x 9800GX2's.
Thanks guys. Well I guess I need to go and get some WinXP licenses.
The box will have 4GB of RAM. With a 32-bit OS, how much of that will the OS actually see with 3 x 9800GX2's onboard? Would I need to go to a x64 OS (WinXP x64)? If I did that, am I going to run into driver issues? or can I just stay with WinXP x86?
I do plan to run WCG and I'd like to be able to give it "some" memory to run.
You'll only see somewhere between 2Gb and 3Gb of ram with a 32 bit OS.
But as the nVidia client only needs ~100 meg to run it, thats fine.
And with the latest 180.60 or better drivers, almost zero CPU time.
