Sorry if this has been discussed before but I did tried to search to no avail. I have also placed this on the Nvidia Forums but it appears nobody from Nvidia visits their own forum.
First my specs:
Ultra Aluminus Case + 2 Antec LED 120mm fans
ThermalTake ToughPower 600w PSU
EVGA 680i SLI Motherboard (latest Bios Drivers )
Intel E7200 w/ Pro Artic 7 HS
OCZ 4GB PC2-8500 (1066mhz)
GTX260 w/180.48 drivers (Primary)
ECS 8800GT 512MB w/180.48 drivers (PhysX)
Acer 22" LCD @ 1680 x 1050
Samsung 750GB 7200.10 32mb cache
CD/DVD/R/W/DL
USB 2.0 5 in 1 card reader
Dual Boot XP Pro W/SP3 + Vista x64 Ultimate w/SP1 Up-to-Date Updates
15.23 Nforce Drivers
6.03 Nvidia System Tools
My problem or issue:
I only Game with my Vista x64 boot, I have been gaming with the ECS 8800GT for a while but decided to buy a GTX260 as a Xmas gift for myself. Because of the prices of the GPU cards being so low, I decided to use my 8800GT as an add-on so I installed the GTX260 as primary and the 8800GT for PhysX. Well, it seems to be hindering me more than it helps. when I play CoD 4 (testing game) using the GTX260 only with settings on Optimal (as dictated by the game) I notice that my FPSs are much better, the gameplay seems to be smooth than when I use it with Both Cards.
Doing a search on Goggle it appears there is a workaround for this issue but this was back in August with the 170 driver series and I thought it would be fixed with the 180 drivers, although, it doesn't seem to be. The work around consisted on using both the vga & dvi cable if you only had 1 monitor and to extend the desktop to the other monitor.
Also, when I try to use the Nvidia System tools, my rig either freezes on me whenever I try to click on any of the performance options or it BSOD's on me with different errors (0x0000003B or 0x00000124 or 0x0000007F) and sometimes it also tells me that something failed with NVOCLK64.SYS but I have not been able to find an answer for this. This happens whether I am using XP or Vista.
Well, I was wondering if there is a fix for the GPU+PhysX issue and if this had anything to do with the problems with the Nvidia System tools.
To offer more information, I have been trying to Overclock my CPU, I took it to 3.0 GHZ stable and I am using a few OC applications to check temps and what have you. The applications I have used are:
REAL TEMP 2.70
RIVA TUNER 2.11
EVGA PRECISION TOOL 1.3.3
CORE TEMP 0.99.3
TECHPOWER GPU-Z 0.3.0
CPU-Z 1.49
HWMONITOR 1.08.0
EVEREST ULTIMATE 4.60.1500
A couple of days ago, perhaps, due to the Nvidia system tools, my rig has been getting stock at the boot loader (according to my wife), she hit the reset button and the pc started normally again. Now, this morning, right before it goes into the prompt to let me choose between XP or Vista, it told me it was in SAFE Mode and I need it to use my Default CPU setting for the Bios and Cmos so, I went to the Bios and Reverted to default setting for CPU and even my RAM.
Sorry for the long rant, I was hoping to be as thourough as possible in hopes that someone here would have an answer for me. I am not a PC Guru but I do follow suggestions and I know my way around a computer as long as the instructions are in layman's terms LOL.
Thanks for taking the time to read this.
First my specs:
CD/DVD/R/W/DL
REAL TEMP 2.70
RIVA TUNER 2.11
CORE TEMP 0.99.3
CPU-Z 1.49
HWMONITOR 1.08.0
