On Linux, yes, but you might need to be familiar with ssh or using a serial console to make setting it up easier. You would have to disable the gpu and set up the virtual machine and gpu for passthrough on the host, which would mean no output from the host. I'm not familiar with the exact steps, but I would familiarize yourself with ssh or serial consoles first if you would like to attempt it.Is it possible without iGPU in Virtual Machine (KVM)?
AMD Ryzen 5 5600X
AMD Radeon RX 6000 Series
Ubuntu
KVM Guest: Windows 10
I have only single monitor.
