cuemasterfl
- Jul 5, 2001
I've been getting a lot of crashes with games just lately, so I installed Everest and found the temperatures inside to be very hot:
Field Value
Sensor Properties
Sensor Type Asus F8000 (ISA A00h)
GPU Sensor Type Analog Devices ADT7473 (NV-I2C 2Eh)
Temperatures
Motherboard 49 °C (120 °F)
CPU 60 °C (140 °F)
CPU #1 / Core #1 52 °C (126 °F)
CPU #1 / Core #2 52 °C (126 °F)
CPU #1 / Core #3 52 °C (126 °F)
CPU #1 / Core #4 52 °C (126 °F)
MCP 93 °C (199 °F)
GPU [ TRIAL VERSION ]
GPU Memory 84 °C (183 °F)
GPU Ambient 63 °C (145 °F)
Seagate ST3750528AS [ TRIAL VERSION ]
Cooling Fans
CPU 1762 RPM
Chassis 1028 RPM
GPU 4718 RPM (100%)
Voltage Values
CPU Core 1.66 V
+3.3 V 3.34 V
GPU Vcc [ TRIAL VERSION ]
I was running WoW a little while ago and the GPU temperature was 202F. All of the fans are working inside and there's very little dust. Why so hot? Could I need a bigger power supply?
Here's specs for the rest of the system:
Field Value
Computer
Computer Type ACPI x64-based PC
Operating System Microsoft Windows 7 Home Premium
OS Service Pack [ TRIAL VERSION ]
Internet Explorer 8.0.7600.16385
DirectX DirectX 11.0
Logon Domain [ TRIAL VERSION ]
Date / Time 2010-04-26 / 22:18
Motherboard
CPU Type QuadCore AMD Phenom X4 9750, 2375 MHz (12 x 198)
Motherboard Name Asus M2N78-LA (Violet) (3 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Video, LAN, IEEE-1394)
Motherboard Chipset nVIDIA GeForce 9100, AMD K10
System Memory [ TRIAL VERSION ]
DIMM1: Samsung M3 78T5663EH3-CF7 2 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
DIMM2: Samsung M3 78T5663EH3-CF7 [ TRIAL VERSION ]
DIMM3: Samsung M3 78T5663EH3-CF7 [ TRIAL VERSION ]
DIMM4: Samsung M3 78T5663EH3-CF7 [ TRIAL VERSION ]
BIOS Type AMI (04/03/09)
Display
Video Adapter NVIDIA GeForce 8800 GT (512 MB)
3D Accelerator nVIDIA GeForce 8800 GT
Monitor LG W2061 [20" LCD] (1904204016)
Multimedia
Audio Adapter Realtek ALC888/1200 @ nVIDIA MCP78 - High Definition Audio Controller
Storage
Storage Controller AOLCKIM4 IDE Controller
Storage Controller NVIDIA nForce RAID Controller
Storage Controller NVIDIA nForce Serial ATA Controller
Disk Drive Generic- Compact Flash USB Device
Disk Drive Generic- MS/MS-Pro USB Device
Disk Drive Generic- SD/MMC USB Device
Disk Drive Generic- SM/xD-Picture USB Device
Disk Drive ST375052 8AS SCSI Disk Device (750 GB, 7200 RPM, SATA-II)
Optical Drive HL-DT-ST DVD-RAM GH40L SCSI CdRom Device
Optical Drive NGTUX VCLQN0LQ SCSI CdRom Device
SMART Hard Disks Status OK
Partitions
C: (NTFS) [ TRIAL VERSION ]
D: (NTFS) 14198 MB (2001 MB free)
Z: (NTFS) 49998 MB (25105 MB free)
Total Size [ TRIAL VERSION ]
Input
Keyboard HID Keyboard Device
Mouse HID-compliant mouse
Network
Primary IP Address [ TRIAL VERSION ]
Primary MAC Address 00-21-00-E1-ED-FC
Network Adapter Atheros 802.11 a/b/g/n Dualband Wireless Network Module (192. [ TRIAL VERSION ])
Network Adapter NVIDIA nForce 10/100 Mbps Ethernet
Network Adapter VirtualBox Host-Only Ethernet Adapter (192. [ TRIAL VERSION ])
Peripherals
Printer Fax
Printer HP Deskjet F300 Series
Printer Microsoft XPS Document Writer
Printer Send To OneNote 2010
FireWire Controller AT&T/Lucent IEEE1394 FireWire Controller (PHY: Agere LFW3226/3227)
USB1 Controller nVIDIA MCP78 - OHCI USB 1.1 Controller
USB2 Controller nVIDIA MCP78 - EHCI USB 2.0 Controller
USB Device HP Deskjet F300 Series (DOT4USB)
USB Device USB Composite Device
USB Device USB Input Device
USB Device USB Mass Storage Device
USB Device USB Printing Support
DMI
DMI BIOS Vendor American Megatrends Inc.
DMI BIOS Version 5.10
DMI System Manufacturer HP-Pavilion
DMI System Product NY464AA-ABA p6130y
DMI System Version
DMI System Serial Number [ TRIAL VERSION ]
DMI System UUID [ TRIAL VERSION ]
DMI Motherboard Manufacturer PEGATRON CORPORATION
DMI Motherboard Product VIOLET
DMI Motherboard Version 3.02
DMI Motherboard Serial Number [ TRIAL VERSION ]
DMI Chassis Manufacturer Hewlett-Packard
DMI Chassis Version Chassis Version
DMI Chassis Serial Number [ TRIAL VERSION ]
DMI Chassis Asset Tag [ TRIAL VERSION ]
DMI Chassis Type Desktop Case
Thanks.
Field Value
Sensor Properties
Temperatures
CPU 60 °C (140 °F)
MCP 93 °C (199 °F)
Cooling Fans
CPU 1762 RPM
Chassis 1028 RPM
GPU 4718 RPM (100%)
Voltage Values
CPU Core 1.66 V
+3.3 V 3.34 V
Field Value
Computer
Motherboard
Display
Multimedia
Storage
Partitions
Input
Network
Peripherals
Printer Fax
DMI
DMI System Version
Thanks.
