GPU or Display scaling
vortexware
What is the best option in Nvidia control panel for scaling: since i am running multiple monitors i was told to switch to the GPU scaling with aspect ration selected, but the Nvidia comes default to "display" scaling, which one is the better option for me, i do run 2 monitors in 60ghz and one in 144ghz
Try which one looks better to you. At native resolution you will not see a difference. GPU scaling allows you to run resolutions that the display scaler may not support at all.
I see, well in that case il leave it at GPU scale but yeh i wanted to know which one was better...
