I been using MSi afterburner with its OSD in all my games now... Heres the prob, i thought it was cpu bottleneck but...how?
Black ops - I know this game isnt taxing but.. everything turned to high playing on a 24 inch Dell at 1920x1200 .. 90 frames.. I know 90 is more then enough and im not worried about the frames so much..just wonder why i only get at tops 30% gpu usage ...
Same goes with Homefront - 70-90 frames only 40-50 Gpu usage...
Even 3dmark11 doesn't max out the gpu's load only 40-50% usage so i dont care about my 3dmark score just wondering if i am getting 8200 score with only 40-50% gpu usage if 3dmark were to max out, shouldn't my score be higher?
but i ran a sandra gpu test and it maxed all gpu cores...odd
Check sig for hardware details....
5970+5870 Trifire - all 900 core 1200 mem
im running 10.12 drivers since they are the only stable drivers i have found to work well
Driver Packaging Version 8.801-101125a-109809C-ATI
Catalyst™ Version 10.12
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1105
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0001
Direct3D Version 8.14.10.0798
OpenGL Version 6.14.10.10362
Catalyst™ Control Center Version 2010.1125.2142.38865
