need some assistance setting up a new system.
I just built a new rig: i7 3770k, Asus P8 Z77-v Pro, MSI GTX 660
I am running Windows 8 Pro with 8gb ram.
The issue is simply that I can not get the FAH GPU Tracker v2 to run with my gtx 660
The error from the log.txt file is below. Can you guys shed some light on the subject?
[22:58:27] --------------------------------------------------
[22:58:27] FAH GPU Tracker v3.54 Startup
[22:58:27] Detected OS: Windows 7
[22:58:29] Detected CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
[22:58:29] 4 Cores, 8 Threads, 3,501 MHz
[22:58:33] Creating client folders...
[22:58:33] Downloading FAH clients...
[22:58:59] Extracting clients...
[22:59:08] Clients extracted successfully
[22:59:08] Setting up clients...
[22:59:08] Client setup completed successfully
[22:59:08] Setting up client configs...
[22:59:08] Setting up GPU0 client config
[22:59:09] Setting up GPU1 client config
[22:59:09] Setting up GPU2 client config
[22:59:09] Setting up GPU3 client config
[22:59:10] Setting up GPU4 client config
[22:59:10] Setting up GPU5 client config
[22:59:10] Setting up GPU6 client config
[22:59:11] Setting up GPU7 client config
[22:59:11] Setting up CPU client config
[22:59:11] Setting up SMP client config
[22:59:12] Client configs generated successfully
[22:59:12] Cleaning up client folders...
[22:59:12] Initial setup complete
[22:59:31] Error running GPU detection:
System.ArgumentOutOfRangeException: Index and length must refer to a location within the string.
Parameter name: length
at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
at FAH_GPU_Tracker_V2.GPUDetect.LoadGPUInfo()
at FAH_GPU_Tracker_V2.frmConfig.cmdDetectGPUs_Click(Object sender, EventArgs e)
[22:59:59] Error running GPU detection:
Thanks
T
Thanks
T
