- Aug 5, 2012
Hey guys it's been awhile since i last posted but I'm looking for a GPU to game at 4K. Not looking for anything extreme just needs to get the job done. Would 2x 980s or 2x R9 Furies be adequate to get the job done ?
Define "get the job done". 60Hz? 100Hz? All eye-candy on? AA or no?
Currently the only single-card solution that will keep you at or above 60hz is a 1080Ti.
A pair of 980's or 980Ti's will probably work as well, as long as your game supports SLI and scales well.
My display is 60Hz IPSDefine "get the job done". 60Hz? 100Hz? All eye-candy on? AA or no?
Cost yesAny reason you are looking at 2 year old cards? You can pick them up for cheap?
"Not looking for anything extreme just needs to get the job done."
If you can bear the mental anguish of lowering settings, you don't need a 1080 Ti. Just lowering the universal settings from Ultra to High can increase performance for minor IQ loss. Might make a 1080 quite capable at 4k, and possibly even a 1070 if you throw in some medium settings like shadows. Some people struggle lowering from max though.
AA no
Doesn't have to have all eye candy
I mostly play Battlefield and AAA games
Don't play deus was boring to me and far cry eitherDepends on the game, but even a 1080 Ti can be not enough in certain titles. For example, in Deus Ex MD or Far Cry Primal, 4K on High settings is a struggle to reach 60fps. On better optimized games, like BF1 you could be alright on max settings.
Honestly, if you are serious, get the 1080 Ti. SLI/CF is a hit or miss (many times a miss) and if you drop to 1 card you won't have the power (outside of old or indie games). Getting a cheap card and then running 4K on low settings would be a waste (and the graphics would likely look worse than if you just had a 1080P TV on Ultra settings).
