CleanSlate
- Mar 28, 2003
I decided to try GPU folding with this EVGA GTX 480 superclock I'm using while my 7970 is out for RMA.
Temps hit 97 degrees celcius 5-10 minutes after starting up GPUFAH before I shut it off. It kept climbing relatively slowly from 95 and I'm concerned maybe there is an issue I need to address with the heatsink but because I recently completely reset the heatsink with AS5 and haven't had an issue with heat before this I'm thinking it may be an issue with with FAH.
I have played games like skyrim and bf3 for hours without ever having an issue with temps going over 85. I have 3x80mm fans and a ~200mm fan in my case as well as exhaust fans and etc. Suffice it to say, cooling has never been much of an issue in this computer case.
I'm wondering what temps other people are getting with this card and if there's a way to control the % load on the GPU?
Edit: Also, these temps were taken with gpu-z and they were the temps from the graphics driver, while the temps given by the sensor chip seem to be about 6 degrees C less at any given time.
