Jomanscool2
- Jan 30, 2007
Hello!
So I am finishing up on a WCed rig in a v2100 and am trying to figure out what to do to keep air moving over the GPU. I cannot use the PlusII fan because of the waterblock on the 8800GTX blocking it. So instead, I was thinking of mounting a 120MM fan as follows, using foam tape and zipties through the holes in the mobo tray (already there). It would blow toward the GPU, and I only have one. Think this is a good idea? or could it possibly cause a circulation of hot air up top?
Lemme know what you think
Edit: Realized that was a bad title =(
If a mod wants to change to "fan blowing on graphics card in v2100" that would be sweet
