GPU cooling
Hi there.
I have 2 XFX 7900GT's running in SLI, and they are damn loud. Does anyone know of any aftermarket cooling devices I can use to replace the stock ones on the cards?
Help much appreciated.
-Covertswine
Covertswine said:
Hi there.
-Covertswine
There the Zalman VF700 series and the VF900 Series. Or the Arctic Cooling nV Silencer Rev 3 which you have to mod/cut about 1-2in off the end or it will stick out OR the Accelero.
You cant go wrong with the VF900 or the Accelero. I recommend the Zalman VF900.
thermalright v1 is supposed to better than zalman vf900...Might be more louder than zalman...
Yeah. If all you're concerned with is cooling, then the V1 Ultra is the king. The VF900 is a good compromise between quiet and cool.
I can attest to the Zalman VF700, theyre VERY quiet and cool much better than the tiny stock turbojetloudashell fan/heatsink. I think the VF900 is a bit overkill, but thats just my opinion.
