GPU COOLER FOR 6600GT?
Here is my Asus EN6600 GT with an Aqua Computer TwinPlex attached. I used the GF4 mounting screen which used the two (2) outboard holes. You can also use the CHIP mounting screen if you want to use two of the four holes that are right next to the block. You can see one of those holes near the bottom left of the block. It would have mounted just as easily with the fittings pointing up, but my personal preference is the way I have it mounted. :)
