I have a GTX 690 and i need some help to install the cables, the GPU come with two cable sluts and also two red cables, i know that i can insert the black power cables directly into GPU, however, i want to know if i can use those red cables. I've took a picture of my current installation. the second cable is setup the same way. are they correct?
http://i45.tinypic.com/2wq5ved.jpg
http://i50.tinypic.com/ix9zs5.jpg
http://i50.tinypic.com/xg2o3.jpg
Thanks
Thanks
