GPU block as CPU block?
ekuest
what are yoour thoughts on this? im tired of this huge dtek fuzion limiting my sff plans. its like 2 inches tall, and then the tubes go out the top making it effectively taller. i have a nice little EK vga-supreme block i want to use instead. its not likei need the best block, and even the best only perform like 5C better than the worst. i figure i can make a mounting bracket pretty easily, and then have a nice low profile cpu block. is there any reason i shouldnt do this?
as long as the base was big enough to accomodate, i don't see why it wouldn't work.
as long as it can get good contact and you can mount it somehow then it will work.
