Got the wrong noctua nh-d14
dewcorps
Hello, I accidentally ordered the noctua nh-d14 2011 se, instead of the 1155 socket version. Should I return the whole thing, and get the right one, or is there a certain part that I could buy that would make it fit?
I know the 1155 and 1156 have the same screw holes, but the noctua cooler I got was for the 2011 socket. I don't know where to get a 1155/56 bracket, as the cooler did not come with one.
Search for Noctua mounting kits on Amazon. I see a few listed there.
Oops.. misread the OP.
Here is what you need:
http://www.frozencpu.com/products/9750/bra-42/Noctua_NM-I3_SecuFirm_2_LGA1156_and_LGA1366_Mounting_Bracket_Kit.html?tl=g48c371s222
Just noticed that if you are willing to wait for Noctua to ship you the mounting kit, you can get it for free.
http://www.noctua.at/main.php?show=nm_i3_upgrade_order&setlng=en
You will probably need to verify that that form is valid for the cooler you bought.
