MrGuvernment
- Aug 3, 2004
Hey all,
Today went to drop off the trash and someone had left these, while not high end, they seem decent enough:
B&W DM303 - http://www.bowers-wilkins.com/Downloads/Product/Archive/ENG_FP12297_DM303_info_sheet.pdf
I tested both using my FiiO E9 Desktop Headphone Amplifier just to see if they work and both do. I wanted to use these for my computer. Noted i have a FiiO E9 Desktop Headphone Amplifier, but it doesn't really have the power to power these speakers (I assume based on specs)
What might be a option for me to power these speakers properly? While my E9 does out put i need the volume about 3/4 to full to really hear things and don't want to damage my E9.
Was thinking something that could easily fit on my desk. I know i could go buy a used amp online or a receiver but would prefer to limit the space used.
- Description: 2-way vented-box system
- Frequency range (-6dB): 52Hz and 30kHz
- Power handling: 100W into 8Ω
- Sensitivity: 88dB spl (2.83V, 1m)
- Impedance: 8Ω (minimum 4.3Ω)
- Dimensions: H 331mm W 201mm D 242mm H 13” W 7.9” D 9.5”
- Weight: 5kg / 11 lbs.
