Got my 930 running.
bustaplz
I recently threw some money at my computer, went from:
E6600 @ 3GHz
MSI P6N SLI Platinum
4GB G.Skill DDR2-800
Zalman CNPS9500
Sapphire 4870
To:
Core i7-930
Gigabyte GA-X58A-UD3R
6GB G.Skill DDR3-1600
Zalman CNPS10X Extreme
HIS 5870
Initial thoughts on the parts.
i7-930:
Same old Intel packaging, stock HSF looks very familiar but possibly a bit beefier than the C2D, C2Q versions.
GA-X58A-UD3R:
4 SATA cables in box, a good start. SLI and Tri-SLI connectors, not that I need them. Very nice looking board and components, solid caps, chipset heatsinks look nice, adequate, but not too big as to be in the way. It has like 10 different LEDs for showing various things like CPU load, temp, voltage. Layout seems logical and none of the board components are in the way of anything. Has a CMOS clear button on the rear panel and of course USB3.0 SATA3 1394 eSATA. Can't ask for much more connection-wise.
CNPS10X:
The box was about the size of my head, almost as big as the motherboard box. Out of the box, it's very impressive looking. PWM mate control seems neat, but I probably won't adjust the fan speed much. Mounting was very easy and solid, cooler base has a very flat and very mirrored surface. Everything about it looks quality.
After installing Windows 7 HP x64 and installing drivers(took all of 30 minutes) I did my first reboot. As the POST screen came up I decided to hop into the BIOS. After about a minute I was rebooting again at 170 BLCK giving me a core frequency of 3.56GHz with no other changes. I honestly just wanted to see how the board would act with a silly OC attempt, but to my surprise it just booted into Windows without a complaint.
Did a brief stress test or two and got the CPU as high as 76C on the first core, installed BF:BC2 and called it a night. The system is faster than I could have imagined, never knew it would be such an upgrade just tooling around Windows, but I can have music, hulu, 3 instances of FireFox full of tabs going any hop into a game without any slowdown.
When I get some time away from work I hope to OC it quite a bit further and reapply my thermal paste(did a bad job) to get my temps a bit lower. Just thought I'd share my thoughts on three products I don't see discussed much on [H].
yeah... I got one last week. I came from a Opteron 2200 so you can imagine how much nicer this is for me :D.
I have it running at 4Ghz now, but the temps seem a little warm although stable. Hovers around 46-50 idle and up to 82 with burn test running (which is way hotter than any thing else i have done on it). Might be my low flow fans. I am still pulling back voltages bit by bit and testing, but video games are taking up too much of my time :p
1.318Vcore, Prolimatech mega.
I'm running 32-36 idle at 166 bclk, no other changes. CPU-Z is showing 3642.7 @ x22 Auto voltage.
small update. i redid my heat-sink and played with the volts some more, 4ghz, 1.3vcore. 42idle, 72 load. probably test for lower tomorrow,
Any perticular reason you choose a zalman heatsink? Glad you like your new system should serve you well for a few good years. Congratulations on it and enjoy.
E6600 @ 3GHz
Zalman CNPS9500
Sapphire 4870
To:
Core i7-930
HIS 5870
i7-930:
GA-X58A-UD3R:
CNPS10X:
Remember Having Hyper-threading on, Increases your CPU temps, and can hamper overclocking.
Also It has been shown to lower Gaming performance.
Just a heads up :) Good luck getting the Magical 4ghz :)
