hey everyone i just played around with FreeNAS and got it installed on my laptop with a 60gb hdd, it was extremely simple to use and setup and now i have a nice NAS drive on my home network. http://www.freenas.org/
you just download the FreeNAS ISO burn it to a cd then boot from it, the setup is extremely simple, i chose the option for it to create 2 partitions one for the FreeNAS software itself then the rest is used for storage, then you just have to assaign it a IP adress on your network and you are all set, just leave the freenas box alone and from any computer on your network open your web browser and point to the IP adress of the freenas box and you get a really simple to use web based gui to set all the settings.
after you mount the hdd and everything its ready to use, its by default set to WORKGROUP but you can change it to whatever you want then it will show up as a computer in your network open it up and there is a share drive you can copy or read from, what i did was map it as a network drive.
now i need to build a real FreeNAS box with some serious storage space any reccomendations on some good HDD's and RAID card?
