Joni Nitro
- Mar 20, 2005
Well, I am at a crossroads. I have been ocing with my P4P800 deluxe for about a year now. It is a good board, but I have been trying to hit 4.0ghz with my 3.2c I can boot and run at 3.8ish, but after a little while the system will hang or restart. I have been trying to narrow the cause down, and discoverd that when running Cpu-z I notice a drop from 1.62 down to 1.55 vcore. The system actually restarted once right as the droop happened.
Now, I am about to end anymore upgrading of the system. I will begin a new build sometime next year once the newer technology is out. I dont know if I should get a new MB, or try to mod this one. I could do the droop mod as well as the others. My cooling and all other hardware is more than suffecient for now.
Here are my system specs:
520W Antec psu
Asus p4p800 dlx
3.2C, 2X80gb Sata in Raid0, X800XT
I have a custom watercooling setup with D-Tek blocks, Via Aqua pump, res, Black ice pro II, and a swiftech NB heatsink and fan.
So, make me some suggestions. Is it worth to change the MB or should I just mod. If I screw up the mods then what MB to replace it. P4C800 dlx? Something different?
520W Antec psu
Asus p4p800 dlx
