Hey guys, I just got a Qpack for a small secondary machine at my desk (Linux machine next to my main Windows gaming machine), and have a question or two. I'll give you my thoughts/mods first:
First off, I'm pretty impressed with the case, and how quiet the PSU is. However, I wasn't impressed with the 120mm fan. After hearing how loud it was, the very first thing I did was tear the old connector off and convert it to a 3 pin so I could manage the speed via a fan controller. It still moves a ton of air, but is now silent.
I used electrical tape to put the HD sensor right on the top middle of my Maxtor. I know the temps won't be perfect, but it does give a ballpark idea. It's reading about 30c for the HD. I am using an older Intel board (2 gig proc), and decided to replace the noisy crappy stock fan with a Zalman. While I was at it, I slipped the CPU sensor between the proc and heat sink. This however isn't working. The Intel utilities read about 50-55c, however the case display registers a constant 25c.
This was just as I was rolling to bed last night, so I haven't torn it apart yet. I'm sure the sensor is secured well between the chip and heat sink, so I'm not sure where the 25c is coming from. Without powering the system down, I was attempting to look at where the sensor connects, but it appears to be inside the front of the case (does it require removing internal components and unscrewing, or does the front just pop off?).
Any thoughts? Any idea why those temps would be off or non-existent?
I'm pretty happy with the case, especially for the price. I think I'll add a small fan of sorts to blow air across the hard drive next.
