got a problem need some help
JonNeff
I have logitech z-680's I think they 5.1 500 watts etc..
now the spot where trouble comes in is just 1 of the speakers will not work as in I switched them up and they all play but the spot I plug into in the back of the sub seems to not put any sound out to the front left.
heres what I am asking is this common ?
Is this an easy fix?
and is it worth it to just fix it?
plz any help is apreciated I absolutely loves these speakers and I really dont wanna get rid of them or buy new ones when it was just the sub what should I do?
well at least it wasnt just me but Im still wondering if I should just go with the creative's that are meant to be used for the soundcard I got.my buddy has the audigy and speakers matched up as in they where made for eachother and hes having no issues and they sound terrific any suggestions on that or what speakers would be best bet and price wise whats reasonable.?.?
Please use punctuation and paragraphs. It makes writing easier to read.
There is no speaker system that "matches" any sound card. They are just speakers.
What is your budget? What will they be used for?
well I wasnt going for spelling and grammer of the year award.
my budget is good enough and most systems I can afford without problems so what do you think sir.
I had a similar problem.
http://www.hardforum.com/showthread.php?t=765405
I had some problems with the left front channel also. After it took out my sub, it would decide to work on its own. Like one minute, it would be normal and another, the sound would be distorted and I'd get crackling. Hopefully, I just got a lemon. I called up Logitech and explained what happen and now they are sending me a new set.
