Oct 20, 2007 #1 A Arnge Limp Gawd Joined Apr 6, 2007 Messages 355 well , i bought it used . it was for like 25$ so it was ok the problem is it came with no speed bracket. so i can't change the speed of the fan is there any software that can do that ? it is a G-Power pro fan. thank you.
Oct 20, 2007 #2 J JaYp146 Supreme [H]ardness Joined Apr 24, 2005 Messages 5,546 Plug it into your motherboard (3pin). Download Speedfan - it will give you fan RPM options.
Oct 20, 2007 #3 A Arnge Limp Gawd Joined Apr 6, 2007 Messages 355 is there anything else but speed fan ? or can you tell how ?
