R
ring.of.steel
Guest
hi, i have got $400 i think it is to upgrade, thats about 200 pounds here. i was wondering what to do with it? more ram, cpu, gpu etc? the rig is in my sig that wants upgrading
thanks
thanks
The only thing I see worth upgrading is the GPU and thats only if you see a need for it. If thats what you want to upgrade, I would go with the 320MB as its just ahold over system and will run great at your res.
Upgrading the CPU isnt going to do much, youll be able to MAYBE get an extra 200-400Mhz on it if your running air. You also have XP SP2 listed so 4GB isnt going to help you at all. You dont have your ram speed listed but you should be fine as long as its not DDR2 533.
