Russ said:You don't have to do push/pull you know. :-P It's not that much better (I think I read 20% real cooling increase/50% more air moved) and it's double the dBA. Plus it will be lighter.
Then you will be able to stick the rad right up against the case and it will have a center of gravity much closer to the case. I wouldn't worry about it in that position.
Nek said:and how soft are Lian Li cases? all I got that I think are useful is a hammer and some nails.. maybe I can like puncture a couple of more holes for the bottom fans
