RTDSpector
- May 27, 2008
What are some good full towers that are easy to install triple fan radiators in?
My PC-V1000B fits a rad on the top with ease, if you're willing to cut it up a bit.
If you want the king for it, Mountain Mods. UFO2 or Ascension. The latter allows upto 3 360 radioators for the overrkill multi-loop.
Croaker
At the cost of a boatload of ugly. Of course, aesthetics are a great deal personal preference, I'll admit that.
Cant be bothered cutting holes for a rad, needed room internally for a triple, and wanted something that looks nice, so went with a Chenbro. Love their cases.
Ask and ye shall receive...Nice choice. I have a feeling thats a bit out of my league. Got links?![]()
Rocketfish from bestbuy if you can find one. Mines in the top. Look at sig for pics
Classic
http://www.mountainmods.com/u2ufo-mirror-black-powder-coat-original-top-p-77.html
Ascension - ultimate in overkill
http://www.mountainmods.com/ascension-black-wrinkle-powder-coat-original-top-p-462.html
While pretty cool, $360 for a case is ridiculous, imho.
I like the Cosmos S, personally. 3x120 + 1x120, plus plenty of size and air-cooling all sound good to me and they can be had for $240 or less. Check for the upcoming revision.
~S
Cosmos S ??? That case is ridiculous... IMHO
The best case, period... The MOUNTAIN MODS Ascention (ie. Big Daddy Special)...
Room for (4) PA120.3, enough said... If you are able to afford $650, will probably never outgrow it. Therefore it's only a one time expense...
Remember the addage, "If you have ask how much it cost, you can't afford it."
Quit bagging products, just because you probably can't afford it...
I believe that the reason that some enthusiasts do not like it, is that it is "made" to be able to be able to easily use 4 360mm radiators. Many enthusiasts like to make something that is completely a one-off that they can claim they did all themselves.
So yes, it may be almost an end-all be-all watercooling case, but for some people, that is the reason they do not like it. However, with that said, if I had the money, I would have two or three of them myself instead of currently using a Mozart Tx right now.
Silverstone TJ07, Lian Li V2000 with the bay mount (assuming you don't need room for more than 3 hard drives)...
Nice case Bio-Hazard! I'm pretty happy with my MM H2G0, but no triple rad for me in this case. A pair of double rads is max, and I like the footprint and horizontal orientation of the motherboard tray.
Cosmos S s by far the best case i have ever used for water cooling. drop in a 3x120 rad without any mods and then decent wire management.. makes it look awesome and cools like a beast.
