I have a computer on one corner of my bedroom that I want to hook up to a monitor on the opposite side (to be used as a TV with PVR software). The monitor needs to run at 1280x768 at 60 Hz (it's an LCD). It's going to be about 13-15 ft total if you include the difference in height.
There is a 5 ft (or so) monitor cable that I used to connect to my monitor on the opposite side of the room. I bought a 10 ft extension cable from Best Buy and hooked it up. There is some ghosting, as I expected.
Is there any way I might be able to get rid of the ghosting? Or is it something that I can't get rid of when I am using this long of a length of cable and this resolution? Might a higher quality cable help, if someone could recommend one? Any advice appreciated, thanks!
