Jul 30, 2007 #1 J jterp7 Limp Gawd Joined Sep 12, 2004 Messages 458 Preferably one that doesn't look a memory stick. My brother recommended hawking but the one he bought 2 years ago isn't available anymore. Any ideas?
Jul 30, 2007 #2 R RoBo 2[H]4U Joined Jan 5, 2007 Messages 3,520 Buy the one from the same range as your router/access point so you don't ever have to play manufacturer monopoly.
Jul 30, 2007 #3 J jterp7 Limp Gawd Joined Sep 12, 2004 Messages 458 my bro picked up a zyxel after realizing that it was our POS linksys router that was causing the dropouts with comcast cable (also has its own issues) I'd like something that doesn't over heat either, the current one we have which is a flexible usb adapter w/ antenna does after extended use anyone have experience with zyxel wireless adapters?
