Good USB drive
Quasimodo
Anyone know a reliable "jump" drive? (key drive, memory key, flash drive, pen drive, whatever) I need one that is at least 128MB and easily bootable. I know they all should be bootable if the BIOS allows it, but I want this to be as painless as possible. I bought a cheap Nexdisk and it worked fine until I used it's utility to make it bootable. Now the partition is screwed up and nothing will repartition it. (can't find any software that will even see it)
The dell ones are suppose to be bootable and the sony one's as well. I'd just rather not spend the extra money for one of those if there is a cheap one that will work just as well. Any advice would be greatly appreciated.
