DarkenReaper57
- Oct 2, 2003
Well, I've been using an eheim 1250 for about a year and a half...and I bought it used. Anyway, I am redoing my w/c system this summer, and the system will be more restrictive with two heatercores.
What is a good pump upgrade? Keep in mind that I don't want to spend too much...as the MCP600 or MCP650s are like...$80.
I was thinking along the lines of a danner mag 3 or mag 5, leaning towards the latter. They are reasonably inexpensive, yet effective. What do you guys think? The mag 5 provides more head and a higher gph at that head than the Eheim 1250. I also have reason to believe that my current pump is...wearing down...and my flow isn't optimal. I could be wrong.
Oh yeah, I read somewhere that some of the mag pumps put out a lot of heat. Will this be a significant issue? I am trying to keep my coolant, and ultimately my gpu and cpu, cool with the new setup I am going with.
Thanks for any input.
