Hello, my friend and I just put together a new system and I was wondering why my benchmark scores are so low for such good hardware...
Sepcs:
AMD 64 3500+ (Stock Speed)
MSI Neo 2 Platinum
1GB G.Skill PC 4400 LE (200 MHz @ 2-2-2-5)
WD 74 GB Raptor (Two other WD drives 120GB and 100GB)
Tyan Tachyon 128MB 9800 PRO
Watercooled CPU and Video card
Eheim 1250...
Windows XP Pro (SP 2 w/ all updates as of 2/27/05)
ATI Catalyst 5.2
DirectX 9.0c
Benchmarks:
3D mark 05 : 1270
3D mark 03: 3188
My first impression is that perhaps my drivers aren't all correct or maybe I need some software that I don't have? I just changed to the new 10K RPM Raptor drive from my old HDs and went from Windows 2000 to Windows XP. In 2000 with the old drives (same everything else) I was able to reach around 6300 on 3Dmark 03 now I get about half that as you can see. I had seen a low score like this before on 2000 and the fix was in my RAGE 3D Tweak program to disable Vertical Sync. But I did not install anything aside from the ATI catalyst 5.2 control center and directx. Have not installed 3D tweak or anything like that... I know my friend mentioned something about updating my BIOS but he wasn't sure how to do that w/ the 64 bit processor and neither am I (to enable higher memory timings etc) But for now I would like to see the benchmarks that this system deserves! Anyone out there with some ideas? Thank you very much.
Sepcs:
MSI Neo 2 Platinum
Eheim 1250...
ATI Catalyst 5.2
DirectX 9.0c
Benchmarks:
3D mark 05 : 1270
3D mark 03: 3188
