Good southbridge cooler for tforce?
High^Life
Hey I've got an Athlon X2 4400+ and have been able to get it up to 2.45ghz stable. I was hoping to push it just a little further but the thing is I'm still using the stock heatsink for the southbridge (I assume the southbridge is the heatsink in the middle of the board?) and the fact that I'm still using integrated gfx probably doesnt help the southbridge heat problem.
I was wondering if this cooler would work well enough?:
http://www.newegg.com/Product/Product.asp?Item=N82E16835103155
or should I use this one?:
http://www.newegg.com/Product/Product.asp?Item=N82E16835103169
Northbridge. ;) In an ATX case, the chip in the middle would be above the chip near the PCI slots (Southbridge). That's the deal with the names.
Anyway, what board are you using? The TForce is the only board where better cooling would help. The rest start limiting because of other problems.
Damn! That second CoolerMaster sink is beefy! I have not seen that. I wonder how well that heatpipe makes connection to the base...
If you want a slightly less expensive alternative, there is the Dynatron I62: http://www.dynatron-corp.com/products/cpucooler/cpucooler_model.asp?id=107 It was $26.50 shipped. Would be quieter than the Swiftech or CoolerMaster. All three of those are probably overkill, but I would have liked to try that CoolerMaster on my P-M...
I had the cooler master on my Northbridge on my ATI chipset board.
It was interfearing with my card cooler (zalman), so I dumped it for the silent zalman NB cooler.
