Good Socket 939 Mobo for OCing?
Discussion in 'Motherboards' started by Avengeance, Dec 12, 2004.
  1. Avengeance
    Avengeance Gawd
    773
    Apr 10, 2004
    Well I bought an Abit AV8 board, that hard ocp said was good for overclocking. Guess they were wrong. This thing hardly overclocks, its never stable when I oc it, no matter how much voltage I give it. Anways I was wondering if there is a board out there for the 939's that are good for OCing. Thanks.
  2. Bugalaman
    Bugalaman Really a Ugandachick
    3,239
    Apr 3, 2002
    K8N Neo2 would be my second choice after the AV8
  3. jetjaguar
    jetjaguar 2[H]4U
    2,538
    Jan 28, 2001
    k8n neo2 plat would have been my first choice
  4. Avengeance
    Avengeance Gawd
    773
    Apr 10, 2004
    Is the MSI board usually pretty good for overclocking? Cuase I keep seeing things for all the socket 939 boards that some are good for overclock and some arent. Like some K8n Neo2's are good and some arent, that you just get lucky or something.
  5. Super strokey
    Super strokey Gawd
    930
    Apr 7, 2003
    Thats the way it is for everything when you oc
  6. Frallan
    Frallan Gawd
    976
    Aug 11, 2004
    Are you sure its the MoBo you could have a "bad" CPU as well...
  7. Shumph
    Shumph Limp Gawd
    400
    Nov 29, 2004
    epox board overclocks pretty good
  8. Lord of Shadows
    Lord of Shadows 2[H]4U
    3,318
    Mar 9, 2004
    For some reason I dont think your going to get what you want out of any board if you cant get it out of this one.
  9. Avengeance
    Avengeance Gawd
    773
    Apr 10, 2004
    Well I cant even get a 250FSB out of this one...
  10. JoeBoomz
    JoeBoomz n00b
    44
    Dec 8, 2004
    Could be a couple things. My AV8 runs happily at 300MHz FSB (though I have the northbridge over-volted and watercooled).
    Is your RAM clocked too high maybe? Try turning your RAM ratio down.
  11. gwai lo
    gwai lo [H]ard|Gawd
    1,690
    Aug 31, 2004
    you're not guaranteed a certain amount of MHz...plus you have to factor in cooling, RAM, and PSU.
  12. MaMMa
    MaMMa [H]ardness Supreme
    6,779
    Aug 11, 2004
    wondering if DFI has a 939 board? I have used 2 DFI boards for my amd xp-m and all I gotta say is WOW.
  13. Avengeance
    Avengeance Gawd
    773
    Apr 10, 2004
    Yea, DFI has a board for 939s. But what I dont get is when I oc my FSB to 300, my vid card has to do a VPU recovery in windows. It will even do that sometimes at 250fsb. Do you think thats the lock not working correctly? Anyways I have the OCZ EL Platinum Rev 2 ram. I put it only to like 250FSB (its what its rated for) and I dont get any ram errors, just my comp wont pass prime for even like 20 mins.
  14. Avengeance
    Avengeance Gawd
    773
    Apr 10, 2004
    Mainly I dont understand why my vid card is resetting....
  15. gwai lo
    gwai lo [H]ard|Gawd
    1,690
    Aug 31, 2004
  16. Avengeance
    Avengeance Gawd
    773
    Apr 10, 2004
    Yes, its on... and yes it is confirmed to be working on the v1.1 of the board which I have
  17. Techmasta
    Techmasta Gawd
    851
    Jul 28, 2003
    No they don't.
  18. Avengeance
    Avengeance Gawd
    773
    Apr 10, 2004
    Oh, ok I was probably thinking the NF3 250gb one... its the 754 one... my bad
  19. vapb400
    vapb400 Gawd
    786
    Sep 19, 2004
    DFI will have their SLI board soon
  20. chipmonk010
    chipmonk010 [H]Lite
    86
    Oct 31, 2004
    i have the K8N neo plat w/ nf3 ultra chipset (socket939) and i was able to boot into windows and run benchmarks (errors in prime) a 300mhz fsb, i run 260 on a daily basis stable in prime.
